メインコンテンツにスキップ
My Optical Drive ejects discs after I insert them.
The optical drive of my iBook G4 ejects discs after inserting them. It can't play discs.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Does it eject all disks or just burned disks? CD's or DVD's? All brands of disks, original disks say from Apple?
さんによる
The iBook G4 I am talking about ejects any discs that is inserted in it, it is to say: blank discs, burned disc, used discs, cleaned discs, CD, DVD, and also the installation discs.
So I do not know what to do, I do not know if damaged at all or can be repared at some way.
HELP!!!
さんによる
コメントを追加
2件の回答
ベストアンサー
This may help: ZAP the PRAM - hold down the option & apple keys also the P & R keys and restart. Continue hold the keys till you have heard three bongs. Test the drive again. If it doesn't work I would replace it. Take the battery out see if there is a tag inside that tells us exactly which iBook you have. I will then be able to direct you to where to get a replacement drive and how to put it in.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Ok, I have an iBook G4 computer with 1.5 GB of RAM and a processor of 1.33 GHZ. Mac OS X Leopard 10.5.8. 12 Inches. I live in El Salvador, Central America.
Help!!!
さんによる
Here's a Combo drive that will work for you: http://www.ifixit.com/iBook-Parts/iBook-... The superdrive, in my opinion is much to high.
さんによる
コメントを追加
最も参考になった回答
Try cleaning the drive with an optical drive cleaning disk
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Chris is right. Sometimes just a lens cleaning restore the drive functionality. I perfer a manual lens cleaning with isoprophylic alcohol but I understand that many people wont open the machine just to clean the optical the drive.
さんによる
コメントを追加
回答を追加する
Samuel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 6,336
