メインコンテンツにスキップ
Sony Computer Entertainmentによって製造されたPS4と通称で知られるテレビゲーム用コンソールです。2013年2月20日に製品の発表、2013年11月15日に発売されました。
1697回答 すべてを表示
My ps4 won't read my ghost recon wildlands disc but other discs work
I recently brought a pre owned copy of ghost recon wildlands. When I loaded the game for the first time after updating the game it said that the disc wouldn't read and that it needed to be cleaned or replaced. I then asked my friend who also has a ps4 to check my disc and it ran perfectly fine on his ps4. I returned the disc and got a new one only to have the same problem on my console while working on my friends. It only happens for this game and every other disc game I have works fine.
If you can help pls let me know. Cheers
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
Had this happen a couple of times for clients. Always ended up being the laser needing to be replaced due to wear.
Some PS4 models you can replace the whole Blu-ray drive otherwise replace the laser caddy if a blu-ray drive board is present.
PlayStation4 光学ドライブの交換
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
This is my only disc game that doesn't work, all others function as normal. Wouldn't a faulty laser result in all disc games not working?
さんによる
Hi!
No, can still be the laser. Does the disc have scratches on it? Your laser is probably already "dying" so it's working less good then it did before. Are all the other games installed before? Some games (when you put the disc in) downloads it's data from the network anyway, other games do install all the data from the disc to the hard drive.
さんによる
It's always the laser in this case. A client of mine had the exact same problem swapped for a brand new disc and still same problem. A laser replacement fixed the problem.
Chances are the disc is a large game that the laser cannot read.
さんによる
コメントを追加
Well if its a used game have you inspected the disc for any marks or dirt. Could just need a cleaning. If the system reads all your other discs its most likly the disc not the
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I doubt it is the disc as the same disc ran perfectly fine on my friends ps4
さんによる
コメントを追加
mines been doing this and i tan ghost recon breakpoint and uncharted just fine they all downloaded just fine and run fine so i will just download it digitally
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Carn O'Hagan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 14
今までの合計 990
