メインコンテンツにスキップ
モデル番号A1312 / Mid 2010 / 3.2 GHz Core i3もしくは2.8 & 3.6 GHz Core i5もしくは2.93 GHz Core i7, ID iMac11,3
383回答 すべてを表示
Utilising an extra eSATA port on my mid2010 iMac
Adding an eSATA port in a mid2010 iMac was announced just a little after the iMac came out and here is an article regarding this at the time… https://www.macworld.com/article/1151094...
Problem is that i cannot find any relative how to video, nor some other info on how to do this right… i wish iFixit could do this :-)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
There really is no secret here! The 2010 27” model has three SATA ports.
Back side of the 2010 27” logic board
All OWC did is design a custom mini-SATA (logic board side) to eSATA cable which is mounted into the port in the logic board and the RAM access door. Don’t forget this system only has a SATA II (3.0 Gb/s) interface so you can encounter issues with SATA III (6.0 Gb/s) drives (fixed). If the drives spec sheet doesn’t list SATA II (3.0 Gb/s) compatibility don’t use it!
eSATA really didn’t get any traction as OS-X (or even Windows) can’t handle loosing access to a drive before properly dismounting. and even eSATA is not without issues with static discharge!
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Why did OWC made a custom miniSATA to eSATA cable? Isnt it possible to find such a cable on the market?
さんによる
It gets into options! OWC thought people would buy theirs over others.
Remember we are past using SATA with Thunderbolt3 & USB-C. Demand for it is not really there any more..
さんによる
コメントを追加
回答を追加する
genik さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 152
