Can the label release lever be replaced? Mine came off.
I attempted to upload a picture of the release lever.
Lever Assembly. When it was "broken off" it was all bent. I placed the metal part between two rigid pieces (I used some pieces of sheet metal, by I imagine wood, or acrylic will work) and then applied pressure over it with some pliers to flatten it. You have to take the side covers of the labeler to be able to set it correctly. There are no screws for the side covers. I disconnected the plug and ribbons, and unscrewed the printer head to the rest of the body thinking it was necessary, and to make easier to look into where the lever went in, but after re assembly, I don't think it was necessary, just remove the side cover from the side of the lever.
The picture shows the notch where the lever goes. I moved one of the ribbons away (it goes through a slot in the assembly to have an unobstructed view
Saludos
このアンサーは役に立ちましたか?
You might be able to re-install it if you can get the unit apart. Yours looks a bit bent, carefully flatten it out should fix it.
Dymo does not offer printer parts as its assumed the device is a throw-a-way!
@kevlove - maybe this image can help explain how a printer works as it’s based on a typewriter!
The platen plate presses the paper to the platen
このアンサーは役に立ちましたか?
What exactly is the part connecting to? l flattened mine but I'm not sure where it connected to inside the printer.
@sochilt - There is a platen plate which this lever pulls away to allow you to feed the label through.
I fixed it! Thanks so much!
Hey guys I literally just got my label printer and the first thing that happened was the lever fell off. What platen plate were you referring to?
@sochilt is it possible you can show a picture of where platen plate is?
過去 24時間: 0
過去 7 日: 20
過去 30 日: 68
今までの合計 1,720
