メインコンテンツにスキップ
2012年半ばモデル、A1278/2.5 GHz i5または2.9 GHz i7プロセッサー。
1624回答 すべてを表示
How to find whats the best Backlit Keyboard Replacement compatible?
Ive looked everywhere and the more i look the more confused i get, some specify models number fr the keyboard and its compatibility and im unable to find my keyboard models number. When i find the one that looks like the winner its usually not Backlit. please send me any further info to clarify this nightmare.
Serial Number: C1MK5CC8DTY4
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
The confusion you are seeing is what the seller is selling you. There are two parts than make up the keyboard the keyboard and the backlight
The Keyboard
The Keyboard Backlight Plate
Rarely do you need to replace the backlight plate. The keyboard backside is the clue if its the correct part note the gaps! This is what allows the light to light up the keys. If its solid then its not the correct part. Also note the key layout is different between the different keys layout, so make sure you get the correct one for your system.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Great that’s very helpful as it saves me from buying something I won’t need.
Basically, some keys aren’t working on my current keyboard due to perhaps damp damage as it stopped working after I cleaned it.
Having said that: I’d be basically looking for a new keyboard and cable connector and it’s keys on a UK layout or US I don’t mind which one.
I’m just facing troubles as to how to find the keyboard model adequate and compatible with my machine. Some vendors specify A6272 number some others just the year and inches, I’m just lost.
さんによる
Let's see if we can save you some money!Lets see if a hair drier is able to dry out the cleaner you spilled into the keyboard. don't use the highest temp as you don't want to melt things. Focus on the keys that are not working. After warming it up let it sit for about an hour and check it, You may need a few attempts.
Replacing the keyboard is not easy! You may want to let someone who's done it a few times to fix your system. We don't have a guide but we do have this one which will get you 80% there MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement as far as the part you can't switch keyboard types! So if you have a UK or EU keyboard you'll need that version, if you have a US (North American) then this is the keyboard you'll need MacBook Pro Unibody (A1278) Keyboard. Watch this vid to get a better idea on the rest of the job Macbook Pro 13" A1278 Keyboard Repair and Replacing
さんによる
コメントを追加
回答を追加する
Wisley Grandizolli さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 48
