メインコンテンツにスキップ
The Xbox One Wireless Controller model 1697 was released in 2015 and replaced the model 1537 controller and fixed some of the problems found on Model 1537 controllers. The Model 1697 controller includes an integrated 3.5mm headset jack, which allows compatibility with most 3rd party headsets without the need of an adapter. This controller has been discontinued and replaced by the Model 1708 controller.
75回答 すべてを表示
My triggers have been acting up
So my controller was completely fine one day until something very strange started happening. I could not move around the home screen so my xbox is pretty much inaccessible. But when I turn it into magnifier mode i can do everything completely fine so i used this opportunity to go into the controller test mode. When i’m magnified every button works apart from LT and RT, but when i zoom our to the normal screen, the test mode shows that RT is being spammed constantly (while i’m not pressing it).
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
if both triggers are acting up then it could be the daughter board. There’s no damage to the chassis holding the triggers in?
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
no, none that i know of.
さんによる
@DaRealGeo 1 I suspect it's the daughter board then that's causing them to activate
さんによる
@aussiepandah i recently opened it up and checked everything it looked fine but it’s still not working imma just get a new controller
さんによる
コメントを追加
回答を追加する
DaRealGeo 1 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 4
今までの合計 60
