メインコンテンツにスキップ
2009年6月発売、2.66, 2.8, もしくは3.06 GHz Core 2 Duo Processor
300回答 すべてを表示
Trackpad works for a short time then start to move erratically
Hi,
I’ve just done a fresh install to El Capitan with a brand new battery on my MacBook Pro 15” 2009.
The issue i’m having is that the track pad works fine for a while and then after 3-4 minutes it starts to behave erratically making it impossible to select anything.
The only thing that fixes it again for a short time is by hitting it fairly hard, after that it goes back to it weird twitching.
I think i’ve tried pretty much everything….
  • Fresh install, happen with both Snow Leopard and El Capitan.
* installed New battery, old one wasn’t bulging
* reset PRAM and SMC (PRAM i got the double chime and SMC the power connector changed colour
* tried with and without the power lead same, same problem
* tried with nothing else is plugged into the computer
* clean it with alcohol and scraped around the edges with a blade
I’m certain it must be a hardware issue as hitting it fixes the problem.
Any ideas welcomed
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Time to replace the trackpad! MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Trackpad and here’s the guide to follow MacBook Pro 15インチ Unibody Late 2011 トラックパッドの交換
MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Trackpadの画像
製品
$59.99
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
The site is called ifixit, not ibuy a new one.
Can you open them up and clean?
さんによる
Just like a worn-out tire you can't do anything to them either ;-}
The sensor plate within the trackpad has become worn or damaged. You need a new one sorry ;-{
さんによる
コメントを追加
回答を追加する
drog1998 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 37
