メインコンテンツにスキップ
モデル番号A1502 / 2.4, 2.6, 2.8 GHz デュアルコアIntelプロセッサ/ 2013年10月発売
Is it safe not to glue in a replacement battery?
I am replacing the battery in a late 2013 MBP Retina 13”. Getting the battery unglued was a royal PITA. Is there any reason not to leave the new battery unglued, i.e. to leave the cover paper in place? Is the glue really necessary?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
1 件の回答
最も参考になった回答
The problem with the rMBP chassis is there are no screw points, so you cannot bypass the double sided tape method sadly. You can probably replace it with weaker tape that comes up easier, but the thickness has to be exact or very close - as in a few mm thinner at most.
The problem is taking the factory tape off of the battery is a high risk procedure as well.
このアンサーは役に立ちましたか?
スコア 3
7 件のコメント:
But won't the battery be held in place by the pressure of the bottom panel? (I actually decided to just go ahead and try this and it seems to work. The battery is not rattling around or anything like that.)
さんによる
@ron Having it loose is a bad idea.
さんによる
You really do need to hold the battery down using the correct tape. A loose battery will stress the wire connections.
さんによる
@danj If the OP changes the tape they need to do it outside and keep the notebook inside. It can probably be done but these are softfcell packs and it's easy to get wrong if you aren't technically capable.
I'd consider changing the OEM tape but I know how much I am flirting with danger. Even then I'd probably put something like Tesa tape over the original since it's so dangerous and it needs to be exact
さんによる
@nick - I haven't had an issue using a bit of solvent to soften the old tapes adhesive.
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
ron さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 22
今までの合計 1,615
