メインコンテンツにスキップ
A Sony Cyber-Shot DSC-W120 is the 2008 entry of Sony's DSC-W series digicams. Comes with a 2.5" LCD screen and a disappointingly small viewfinder.
8回答 すべてを表示
Is there a way to fix water damage?
My daughter had her camera in her backpack and her water bottle popped open and got everything wet. It wouldnt tun on after that. This was a couple years ago, and it still wont. She said it didnt get very wet so I thought it would dry out and be ok. Is there anything I can do to find and repair it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
but my cam not fix still i opened and saw it some damage in motherboard like sky blue how to fix it please help me
さんによる
コメントを追加
2件の回答
ベストアンサー
My concern at this time would be corrosion. Hoe you removed the battery. Make sure the contacts have not corroded. You could follow the teardown from here to disassemble your camera. For any liquid immersion, I would suggest this guide. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 6
コメントを追加
Dropped the camera out of my hand on the ground and when they run did not operate how repaired
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
shanda さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 21
今までの合計 6,860
