メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号はA1059もしくはA1099 / 20、40、60 GBハードドライブ / タッチ反応クリックホイール
Why doesn't it work when unplugged?
It works when plugged into pc. It shows a full charge but doesn't turn on when unplugged. What is wrong? How can I fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
7件の回答
最も参考になった回答
Sounds like replacing the battery would solve the problem.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
I had a very similar problem. The charge on my 4th Gen Photo battery would last less than 30 min. before completely depleted. In addition, I would plug in the firewire charger into a wall outlet noting that the date and time would reset to Jan 01, 2000 0000hrs. I did not lose any on my tunes. Thus I only listened to it if I was able to plug in in to an outlet somewhere.
After seeing the replace battery suggestion noted above, I did just that. I disassembled my iPod and discovered that the battery within was bulging from the center --- (I had a similar problem with a cell phone battery that fail to maintain a charge) --- swapped out the batteries, charged it up and have not had a problem since. With the proper tools I had purchased here at iFixit (yes, you need the spudger to remove the old battery), my total repair time was less than one hour.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
hi, mi I pod got stuck on one song and it will not turn off or change to any tracks, what could be wrong
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
please start a new post- just ask a question :)
さんによる 共有
コメントを追加
Have you tried a soft reset first to get back to the startup screen?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My iPod will turn on if plugged into the Bose Dock player but will not if held in hand
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
After charging with PC USB it got stuck with eject option. But nothing is happening with My Apple IPOD just showing msg eject before remove.
Please help
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
tell me what i cant do
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
cindy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 14
今までの合計 3,667
