メインコンテンツにスキップ
2011年後期モデル番号A1278 / 2.4 GHz i5 or 2.8 GHz i7 プロセッサー
591回答 すべてを表示
MacBook Pro won’t charge after water damage
Hi there, I searched for the right answer already and have some questions left.
I spilled a little bit water on the left side (logic board side) of my MacBook Pro 13” (Late 2011). The battery didn’t work afterwards. I bought a new one and now I realise it must be a different problem. If I connect the MagSafe Connector, the green light (not the dimmed green light) comes on and the log-in pages tells me 100%. After the log-in the Mac shows the right percentage (~50% atm). My sister has the same laptop and is in the town atm, so I can test some parts. Which one should I test? Could it be a faulty MacSafe DC-In board even if it’s not the dim green light in my case?
I can provide pictures (in better quality) if necessary. Just tell me what you want to see.
Thank you very much
Paul
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
The DC in board could Part of the problem, but really the most important thing is to look all around the logic board for any corrosion. If you find any, look to what it does, does the trace connect to a battery monitoring chip? Does the pin on the chip connect to the DC in board? Look all over, even on the other side of the board, for any corrosion at all. My 2009 MacBook Pro was completely wiped out by a little bit of corrosion smaller than a crumb, so it is definitely possible that the power delivery circuit, which is on the edge of the board, was damaged.
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
Thank you, Jon. I appreciate your comment. Do I just look or do I clean it?
さんによる
If you find corrosion you need to try a couple things. First of all, try to see if you can dissolve it with isopropyl alcohol and test the laptop. If that doesn’t work, you need to find where the corroded trace leads to and solder on a jumper wire.
さんによる
By the way, you should be able to look up schematics online to find where you need to run the wire.
さんによる
Thank you very much. Tbh I just cleaned some places with a mix of distilled water and mostly Sterillium (antiseptic with 99% ethanol). I searched what I should look for but I couldn’t find places with the same pattern except one. However, it seems to work now which would be awesome. Thank you very much for your help. Maybe I can find the schematics later and see if the wire is where the potential corrosion was.
さんによる
I’m glad to hear that it worked!
さんによる
コメントを追加
回答を追加する
Paul from Berlin さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 13
今までの合計 164
