メインコンテンツにスキップ
食器洗浄機の修理と解体ガイド
707回答 すべてを表示
Dishwasher will fill up but not cycle or wash dishes
I have a whirlpool dishwasher WDF520PADM7. About 3 years old. The dishwasher will fill up with water but then does not wash. It seems like it thinks its going through the cycle because the soap dispenser pops open. But all it does is fill up and drain. I tried multiple cycles and even worked with the door latch to see if that maybe an issue. I already tried cutting the power and turn the fuse back on. I have a feeling from what I have read that it is the sump and motor assembly. Does anyone have any feedback?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
Hi @apratter12 ,
Check behind the kickplate (toeplate?) or door panel, to see if there is a "tech sheet" there. If there is this will show how to get into the diagnostic mode for the dishwasher, which may give some clue as what is or is not happening.
Here's a link that may help if there is no tech sheet but not sure if this is for your particular model.
Have you checked that the hot water supply is at the correct temperature and pressure at the dishwasher?
According to the manual it says the dishwasher must have :
A hot water line with 20 to 120 psi (138 to 862 kPa) water pressure can be verified by a licensed plumber. 120°F (49°C) water at dishwasher.
If the water is not hot enough it may be waiting for the heater to heat it up but the heater can only raise the temperature by about 40-60F which may not be enough if the water is too cold. Just a thought.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I had the same problem, went through all the online discovery Youtubes and blogs, replaced controller, water inlet valve, plunged the kitchen sink, cleaned all filters, and still there was no wash. Here is my solution: IF your dishwasher is 4 or more years old where it fills and drains and seems to go through the timing, but the washer arm(s) are in the same position as when you started, AND you have cleaned the filter and washer arm(s), then it is likely the circulation pump. I got one from Amazon for $99 (plus $15 for extended warranty), followed a wonderful YouTube that was on that Amazon pump sales page, and the dishwasher cleans like new!
I took advantage and also cleaned behind all the manifold tubing that carry water to the arms (they were YUCK behind them), and am a very happy now.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Keeping your water pump clean helps tremendously
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
AdamNSD さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 156
