メインコンテンツにスキップ
20-inch, 23-inch, and 30-inch aluminum LCD displays introduced by Apple in June 2004. Models A1081, A1082, and A1083 respectively.
99回答 すべてを表示
Apple Cinema Display and USB-C Adapter
Hi All,
I’ve had my HD cinema display for about 10 years now, and absolutely love it. It’s worked great with my 2013 Macbook Pro.
The screen has a DVI connector by default, and I’ve been using it with a DVI > Mini Display Port adaptor, which has worked like a charm.
I since have a new MBP, which has USB-C connectors. I changed out the DVI > Mini Display Port for a DVI > HDMI adaptor, so that I can connect to the Apple 3-in-1 USB-C connector.
The screen now will not display any image when plugged in. The laptop appears to recognise the screen, however the HD display is black.
I’d really appreciate any guidance as to how I can work around this.
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
There are some USB to DVI connectors that should work, but you need to find one that can handle the resolution of your monitor. Probably an active adaptor is required, and those are more expensive.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Drew さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 407
