メインコンテンツにスキップ
より早い処理スピードを可能にしたiPhone 3Gのアップグレード版です。このデバイスの修理は3Gと似ており、標準のドライバーと開口ツールが必要です。モデル番号 A1303 / 16 もしくは 32 GBの容量 / ブラックもしくはプラスチックの背面ケース
1500回答 すべてを表示
Reboots every 3 mins after battery replacement
I did a refurbishment on my 3GS and replaced battery, front panel kit and the rear case.
The phone boots fine, everything works, but after 3 mins the phone suddenly reboots. Also the battery seems not to be charging.
I reopened and remounted everything and made sure that all connectors are in place, all skrews are straight and locked and so forth.
I also weared an anti-static wristlet during repairs.
Any ideas? Is there a way to run kind of logic board tests for an iphone?
- Dieter
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
dieter this is perhaps one of the most common questions on ifixit for iphones.. there are plenty of similar answers too, so have a browse under the photo of the phone at the answers. Basically your phone isn't recognising the new hardware. If you put your old battery back in then all should be fine again. If you try and restore in its current state then you'll most likely get error 29. The solution is to request an exchange from iFixit. It is a bit of pot luck whether your phone will accept the new battery as not all apn actually mean anything on OEM batteries these days. good luck. if that doesn't solve the problem let us know.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Well, I bought the replacement battery from ifixit.com, so I assumed the replacement parts they sell would work.
Tonight I´ll replace the battery with the old one and see what happens.
Thanks for the answer.
- Dieter
さんによる
thing is that 8/10 people who buy there battery will have no trouble.. ifixit is pretty good about aftersales. should be a contact no. on your shipping form
さんによる
コメントを追加
回答を追加する
dieterdirkes さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 2,852
