メインコンテンツにスキップ
2.0GHz, 2.3GHzもしくは2.6GHzクアッドコアIntel Core i7プロセッサ (Turbo Boost 最大3.8GHz) 6MB共有L3 キャッシュ付き。
580回答 すべてを表示
Not able to left click. Firmware issue?
I have a Late 2013 15” MacBook Pro that won’t left click. Right clicking works just fine. Note that the physical clicking movement works fineThis happened randomly about a year ago. After getting a $500 estimate from several different places to replace the top case, I put it in a cupboard and got a new MacBook.
Fast forward to today… I’m bored. I picked up a new top case on eBay and installed it myself. But now, the issue persists.
The weird throng about this is I can’t left click with anything. External USB mouse, external Bluetooth mouse, nothing.
Ive noticed that it I can left click with an external mouse in the boot menu but only sometimes with the internal trackpad.
The other weird thing is if I disconnect the trackpad cable from the logic board, I can use an external mouse with no issues.
I suppose its possible both top cases have the same issue but I find that unlikely.
Here are the things I’ve tried:
Resetting SMC
Installing a new SSD
Re-installing MacOS
Installing all available updates
Can this be a firmware issue? If so, how can I fixit it?
Thanks in advance!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I think your real issue is a messed up Trackpad cable I would have replaced that alone 15” Macbook Pro retina Trackpad Cable, Apple P/N 821-1904 or the full Trackpad MacBook Pro 15" Retina (Late 2013-Mid 2014) Trackpad
This is not a logic board firmware issue.
MacBook Pro 15" Retina (Late 2013-Mid 2014) Trackpadの画像
製品
$69.99
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
So you think both top cases have the same issue?
さんによる
The uppercase typically doesn't come with the Battery, Trackpad cable or the Trackpad its self as a proper Apple part. As an example 15" MacBook Pro retina Top Case & Keyboard
If your's came with a trackpad I would swap out your original trackpad over. to see what it does then. There is firmware within the chip thats on the trackpad cable which maybe your issue.
さんによる
コメントを追加
回答を追加する
Austin Martin さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 43
