メインコンテンツにスキップ
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
154回答 すべてを表示
Taking long time to start
Having to hold key a quite awhile to start. Acting like it was t getting fuel. Replaced fuel filter and put new spark plugs. Didn’t fix so put on computer. Threw the code for cam shaft sensor. Replaced today and still is the same. Any ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I had this problem a while ago and it ended up that my alternator was dying after I got it replaced the problem went away another way to check if its the alternator as if you turn on the indoor light when the engine is running and if it flickers that is a common symptom
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dawnn さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 6
今までの合計 27
