メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Manufactured from 2004 to 2009, the Vino 125 has a 125cc engine.
Fuel leaking from an open hose coming from bottom of carburetor I
Trying to figure out why fuel leaks steadily out of a very small hose coming from be very bottom of the carburetor. Hose does not appear to attach anywhere seems like an open hose. Leaks only when running. Also a thicker hose coming from mid carb leaks some as well while running. That hose Appears to be a vent hose of some sort and is sliced add a 45 at the end. Final note I have got the scooter to run smoothly but just facing these leaks any information would be greatly appreciated , the gas tank is nowhere near full checked already.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
2 件のコメント
were you able to fix this? I have the same problem
さんによる
Carburettor’s usually have a float inside the float chamber which rises and fuels as fuel is used by engine. The float operates a valve which gets closed off when float chamber is full and opens when float falls As fuel level reduces. This is a factor of engine speed, the faster the engines goes more fuel is used float falls as fuel level goes down, float valve opens and fills up float chamber. Common fault is float valve sticking open, float chamber fills and overflows sometimes thru a small pipe.
さんによる
コメントを追加
4件の回答
ベストアンサー
Float needle is or seat is no sealing properly causing excessive fuel to fill the carburetor bowl going into the overflow.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
Hi,
Don’t know the answer but here’s the service manual for a YJ125S scooter. Hopefully it is for your year model as it says 1st. Edition Nov’ 2003 on p.2 of the manual
Section 6 in the manual details how to check and test the carburettor.
Hopefully this is of some help.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
Thx Jeff I will check it out!
さんによる
Sorry jeff! Do you have service manual for boxer 150? Help please
さんによる
@jacksonmwingira
Sorry, no I don't.
さんによる
コメントを追加
The float lifts a needle valve as the float bowl fills. If the needle is stuck or damaged, it won't seal, and fuel will run out the vent tube. Sometimes, a good tap will remind it where it belongs, but in my case (Vino 125 sat for 12 years), the carb needs to come apart for some serious TLC.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Suppose to be open ended. It lets overflow of gas in carb to drip on ground.
I had the same question. Thought something was wrong but it’s suppose to be that way.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Valve inside carb float chamber should close. No fuel should escape.
さんによる
コメントを追加
回答を追加する
Aaron Chookul さん、ありがとうございました!
統計データ:
過去 24時間: 10
過去 7 日: 37
過去 30 日: 112
今までの合計 7,573
