メインコンテンツにスキップ
モデル番号A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5もしくは3.8 GHz Core i5もしくは4.2 GHz Core i7 Kaby Lakeプロセッサ (ID iMac18,3) / Retina 5Kディスプレイ。システムは類似しているため、修理ガイドについては旧モデルのiMac Intel 27インチ Retina 5Kディスプレイ (Late 2014 & 2015) を参照してください。
293回答 すべてを表示
締切られた回答
Hard mod to overclock CPU/GPU?
Look I don't mean to come across the wrong way but if you don't know how to do it don't say it's ‘impossible’ - your ignorance doesn't make it impossible and I will vote you down. Also I do have more than a few posts here where people said it was ‘impossible’ and I did it anyway so there's that too…
And yes I am aware temps will be a problem but I got a plan to sort that so the question remains: how to hard mod the iMac and get the CPU (and maybe the GPU) to overclock?
I'm thinking something that would be stable on a regular PC perhaps about 15%~25%…?
Small bump in voltage along with changing FSB multipliers maybe…? Any ideas?
I'd be keen on a softmod as well but that would likely be overwritten everytime I upgrade the system so a hardmod would be more what I'm looking for :)
(Can I attach the schematic and boardview here or would it go against the rules?)
Any actual help would be nice. Why can't we show PC people they are not the only ones that can have fun with their mods…? ^^
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -2
5 件のコメント:
Any time someone starts a question threatening the answerer I avoid it.
さんによる
@mayer - I know.... Carlos never likes any answers we give him. I wish he would first try to understand the basics and not always trying to prove people wrong.
A brain surgeon didn't just get out of high school and opened a practice, they spent many years of learning. And even then try to understand more by seasoned pro's learning on what they know.
さんによる
@danj This guy has down voted you 6 times and me 4 times. He doesn't deserve the time of day from either of us.
さんによる
@mayer - Yep! You're right.
さんによる
And what help any of you actually offered?
"-Hi my screen flickers when I use Outlook please help.
-Your display is dying and you'll have to replace it""
No! All I need to do was to downgrade the Outlook version then after a few updates MS fixed the issue and it never happened again. Were I follow your advice it wouldn't have done anything to fix it and I would had spent over a thousand dollars for nothing!
"-Hello I'm having issues that are not described on the guide please help.
-Here's the link to the guide please upvote me"
No! I already said it's not on the guide and you're not helping at all why should I upvote you?
Eventually I found out the answer myself and posted there and you say I don't like the answers given? Send something helpful - even a link pointing to find a solution - not a canned reply that I should buy a replacement or a copy/paste to something I already stated ain't helpful.
I'm pretty sure this is called iFixit not i.will.tell.you.to.buy.replacement.parts or here.is.a.useless.link
さんによる
コメントを追加
1 件の回答
The best answer here is to study the Intel CPU documentation:
Intel® 64 and IA-32 Architectures Developer's Manual: Vol. 1 as well as all of the others (total of eight) to understand what is possible.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I'm pretty sure there is no mention at all to any iMac in those pages can you prove me wrong?
Oh right you are the guy who said my display was dying when Outlook started to cause flickering. Guess what I downgraded the Office version and never happened again.
Or that time you said my M.2 drive was dying? It was the exposed adapter so I just covered with thermal resistant tape and done.
Or when you said I couldn't instal an IR receiver using the USB port? Yeah I successfully done that too!
What's the deal you work for Apple and your job is to tell people to buy it new whenever something goes wrong like they do in the Apple 'support' pages…? Not cool dude… ¬¬
さんによる
Your very right! There is nothing on iMac's or any Apple product in the Intel docs!
The point is you need to understand the Intel chip architecture to then understand what can be changed. I've spent many an hour reading them. Once you've read the needed chapters you will have the foundation to alter the EFI code which controls the CPU timings.
さんによる
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 72
