メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2690回答 すべてを表示
iPhone 6s black screen and not recognized from pc
Hi, my friend has an iphone 6s that suddenly has black screen and it does’t recognize from any pc. I’ve tried to change several display but nothing, ever black screen. I’ve changed battery e charging port but still non recognized from any pc. If I connect a usb tester to the phone and it absorbs about 1mAh-1,4mAh. Thanks in advance.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
5 件のコメント:
Was the battery disconnected while attempting repairs?
さんによる
Hi, yes of course.
さんによる
Test the power lines with a multimeter to see if any are shorted
さんによる
Hi, thanks to everyone . I've solved. Problemes was the lcd connector and the screen changed. With a clean to connector and a new screen everything is ok. Thanks in advance.
さんによる
Ok glad to hear
さんによる
コメントを追加
1 件の回答
Try a hard reset, you can look up how to do it on YouTube. I would also check the tristar ic with a tristar tester. The tristar ic is the chip that controls the charging and its also the chip that allows data to go from the iPhone to and from the computer. It will work until the battery dies but it won't recharge it. Try putting in a new battery, if it works it's a 99 percent chance it's the tristar ic
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Ho, thanks for answer. I' ve solved changing screen and clean motherboard connectors Thanks.
さんによる
コメントを追加
回答を追加する
Rosario Mangiagli さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 98
