メインコンテンツにスキップ
モデル番号A1990。2019年5月発売。6コアもしくは8コアプロセッサのオプション付き。
87回答 すべてを表示
Help identifying connector between logic board and touchpad (maybe)
Alright gang.
I have a 2019 MacBook Pro that has one of the connectors burned. Please see photos. Disregard “battery connector” label. We know it’s not that.
It is located at about 5 o'clock of the left fan with the Mac battery closest while viewing. The ribbon cable that attaches to the burnt connector is secured by a metal plate with two screws. The ribbon cable goes under the logic board and into the keyboard. I suspect connected to the touchpad maybe.
It is the same style connector as the rectangular touch pad connector on many of the newer MacBook Pros. It has 40 pins to be soldered to the board.
Here's what info I believe to be correct: Hirose df40. I cannot find one that has 40 pins, though.
Thanks for whatever help you give.
Chris Leeds
Well Connected Life
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Since this is covered under warranty, why would you attempt repair?
Any machine that I have problems with during the first year, I always that out the extended two years of AppleCare.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Because Apple hasn’t add liquid damage to its limited warranty coverage. This Mac took a drink.
さんによる
You are going to need to the part on a donor board. The only person I know of that might have it would be Louis Rossman
https://www.rossmanngroup.com
さんによる
Thanks. I submitted this post from my request to rossmangroup Kevin responded, and we were making progress until he asked me for the connectors”J number.”
I have been very prompt in my responses to rossmangroup, who have now gone silent.
I have since learned that’s an identifier from the schematic, which I don’t have. I find them online for $$, but even if I bought one I wouldn’t know what I’m looking for.
Anyone out there help me identify this connector so I can at least refer it by name in my attempts to locate a replacement? I’ll submit a photo of the male connector.
Thank you.
さんによる
Rossman is in NYC, it's Friday and they may have closed down for the weekend.
さんによる
コメントを追加
回答を追加する
Chris Leeds さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 4
今までの合計 269
