メインコンテンツにスキップ
2014年4月のアップデートによりアップルの13インチMacBook Airはデュアルコアi5またはi7プロセッサーの更新とわずかなバッテリー性能の向上がされました。
Internal mic and speakers not working on Mac Air
Hi! When I tried to use my laptop this morning, the internal speakers and mic weren’t working and no longer show up on the System Preferences.
I’ve looked for results and tried:
restarting computer
restarting PRAM
restarting SMC
plugging headphones in and out (they don’t appear as an option either)
rebooting the audio in the Activity Monitor
going to ‘diction’ and trying to calibrate the mic that way
Bluetooth is still working and the sound works through a bluetooth speaker. I didn’t have an accident with water or banging the computer or anything.
Any suggestions?!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
Thanks so much for your help—I actually found some advice elsewhere to try sticking a toothpick in the headphone jack to see if something was stuck there. I turned the computer off and did that, and a bit of fluff came out, and when I restarted the computer the sound and mic all worked. Hopefully these answers can help someone else in future!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Yes! Many thank sJane. That worked for me. I had no internal speakers or mic and, crucially, no startup chime so it was obviously a hardware issue. Turns out to be something as simple as a clog in the headphone socket flagging to the mac that a headphone was connected and cutting off all internal sound i/o. Wooden toothpick probe worked a treat. :)
さんによる
コメントを追加
最も参考になった回答
Hi Jane,
2 things i would also have checked;
  1. Click the  logo, hold option/alt key, click System Information. look under audio on the left and see if any devices show up.
  2. Add another user account to see if it’s a preferences issue.
Failing that, check some good tips here, https://osxdaily.com/2015/03/01/no-audio...
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Where do I find  logo on my MacBook air to check my audio devices?
さんによる
@littlelove1 - Look at your menu bar in the far left corner.
さんによる
コメントを追加
回答を追加する
jane さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 7
過去 30 日: 39
今までの合計 6,118
