メインコンテンツにスキップ
The Casio CTK-3000 has 61 keys (5 octaves), about 400 instruments, and a built-in metronome.
Static in right speaker and low volume in left speaker.
Hi. My father has a Casio CTK-3000 which he has owned for a few years. He turned it on today for th first time in several months and now there is static in the right speaker and low volume on the left speaker. We've tried connecting to an amp and the static is still there. We have even tried plugging it into a different outlet and still the same result. While it was not being used, it was covered.
Does anyone have any ideas what might be causing this. Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Internal wires or cut or severed. It is toast. That happened to mine 6 months ago.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Sorry to hear that tho...
さんによる
コメントを追加
Try check and replace the op amp after the DAC output. I fixed a Yamaha piano having the similar issue. One of the troubleshooting method is to probe the signal directly from the op amp output pins of both left and right channels to see if it's any abnormality in the sound.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Yves さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 591
