メインコンテンツにスキップ
1.86GHzもしくは2.13GHzプロセッサ、フラッシュストーレッジは128GB もしくは256GB
147回答 すべてを表示
Power issues, not recharging or switching on
My computer was initially not holding a charge and warned me that the battery needed replacing. I procrastinated replacing the battery, it stopped recharging intermittently and wouldn’t always turn on. I took it into Simply Mac and they ran diagnostics and told me I needed a new I/O board but I had to order one from a 3rd party, yada yada…
So I skipped spending the coin at simply mac and replaced my I/O board and battery myself. I wasn’t particularly impressed with the “new” (refurb) I/O board as it has signs of corrosion on the port (I had to get it from someone other than ifixit as they were out). Got the replacement I/O board and battery in and for a while I was a happy camper… I still noticed some issues. Like the computer would only charge with the charger oriented in one direction and sometimes I would have to tweak it a certain way to get the little light on the charger to turn orange to get it to charge.
Now computer has stopped charging completely and once again I’m unable to turn my computer on. Is the replacement I/O board that I installed faulty..? Or is something wrong with my charger? Or is it something else?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Lets go through the basics:
Review this Apple T/N Apple Portables: Troubleshooting MagSafe adapters Make sure the MagSafe cord is not damaged. If it is you’ll need a new charger. Also make sure the systems contacts are clean and gold colored, not black!
Make sure you have a real Apple charger, there are a lot of fake units which can harm your system and you! OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth This is why the contacts can be black Lacking safety features, cheap MacBook chargers create big sparks
The last step is to monitor your battery and charger using this gem of an app CoconutBattery Take a snapshot of the apps main window and post it here for us to see [iFixitでの質問に画像を追加する方法|
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ross Lesslie さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 28
