Touch Bar not working ,tried 4 different types of resets
Touch Bar on 2019 MacBook Pro stopped working and have tried 4 different types of resets
Your system is likely still under warranty, if you took out the AppleCare+ extended warranty you also have it, I would recommend you call Apple to at least check.
Its a bit of work to get the old Touch Bar out to replace and right now the part is not available. Apple basically replaces the full uppercase assembly.
このアンサーは役に立ちましたか?
1-800-myapple
過去 24時間: 1
過去 7 日: 3
過去 30 日: 4
今までの合計 84
1件のコメント
Can you list out what you've tried so we don't repeat.
Dan さんによる
