Water is leaking under the washer during the fill cycle.
I have water leaking under the washer during the fill cycle. The leak doesn’t happen during the rinse cycle. Is there a home repair I can make?
Leaking during the fill cycle might be caused by the air gap, which is a small device installed by the manufacturer that prevents the washing machine water from being siphoned into the household water supply. ... If a component within the air gap is cracked or damaged, the hose will have to be replaced.
Please give us your exact model number.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 5
今までの合計 80
