メインコンテンツにスキップ
モデル番号A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duoプロセッサ
310回答 すべてを表示
Internal display black, external workings fine but...
iMac working on external display
  • problem
  • Inbuilt display not working .
  • There are only 3led physically present on motherboard No.4 which is mentioned in attached image start with iMac start but turn off automatically after few seconds.(after removal of lcd screen)
  • but still external display working fine.
  • Very very light display appear sometimes.
confused
  • inverter problem?
  • lcd to inverter cable problem?
  • backlight problem?.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
likely you snapped some cable while disassembly. Carefully disassemble and check everything.
> Mac hdd show multiple error message while OS X installation.
Next this happens, use something like http://www.system-rescue-cd.org/ ISO on a USB stick to verify and check HDD/SSD. command: smartctl
Just do not disassemble immediately.
さんによる
- Everything I solved successfully .
- No cable snapped checked twice
- Now facing Only 1 problem screen problem (very light display)
- I know it is inverter or lvds cable or back light or in same cases vertical synchronise cable problem.
- Need help how to diagnosis one by one?
さんによる
コメントを追加
1 件の回答
You need to replace the LED driver board.
iMac Intel 21.5" EMC 2308 LED Driver Board Replacement
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kailash Kamble さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 80
