メインコンテンツにスキップ
モデル番号 A1213/ 8, 16, 32 GB容量
216回答 すべてを表示
Shows up as "No Wireless" - just grayed out
Hi. I just replaced the battery on an iPod Touch 1st generation that was working fine before, but now, after it's put all back together it works great except the Wi Fi option is just grayed out, saying "No Wi Fi". I suppose I must have bumped something when reassembling, but how do I fix it? Is it the small antenna wire at the top that is causing this or something else? Do you think I just need to re-align the antenna or is there something else that might have gotten mixed up?
Thanks for the help!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
I would open up your iPod again and check the connections. The WiFi antenna is connected to the logic board by contacts points only. Make sure that those points still make contacts with the board. Check the guide on here. Of course, check and double check all other connections as well. Hope this helps, good luck to you.
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
Great thanks, I didn't realize it was only connected by the contact points, I thought I might have broken it off but wasn't sure. It was a bit corroded, so I think I'll try replacing it with another one. Thanks!
さんによる
Good luck, hope it works for you.
さんによる
コメントを追加
回答を追加する
iTronics Repair さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 13
今までの合計 2,197
