メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号はA1708/EMC 3164。2017年6月発売。このエントリーレベルのMacBook Proには伝統的なFunction Keyが搭載されています(OLED Touch Barの反対)。
Can USB-C issues be caused by low battery capacity?
Hi all,
Recently out of nowhere my MBP 13” (function keys, 2017, no Apple Care, out of warranty) started acting out in the following combination of ways.
THE LIST OF ISSUES:
  • Both ports stopped recognizing external display using the usb-c to hdmi adapter I used reliably a while before
  • Around the same time my battery started reporting “Service Battery“ state
  • The USB-C port closest to user (front) is only taking ~5V when charging, while the other USB-C port (back) is charging at ~19V (I have current measuring USB-C device)
  • If I want to use external SSD for backup/data transfer it works on both ports but sometimes I need to plug the other port for charging for device to be recognized
  • Up until recently, I also noticed that sometimes MBP would shut down when I would close the laptop instead of going to sleep (though after resetting SMC/NVRAM I never experienced this again)
WHAT I TRIED:
  1. resetting SMC/NVRAM
  2. updating system to the latest MacOS version
  3. running diagnostics (only service battery was reported, which later on disappeared)
  4. plugging/unplugging cords in different combinations
  5. using different usb-c hub with direct power-in that used to work before as well
Here is the charging report from CoconutBattery
For back USB-C port:
For front USB-C port:
QUESTION:
Is there any chance this issue will be resolved (especially the one about recognizing external display) if I would just replace MBP battery?
Or is this almost definitely characteristic of logic board issue?
I was thinking about taking up a task of buying a replacement kit and replacing the battery myself while in self-isolation due to pandemic, but would not attempt replacing logic board myself.
Thank you in advance for your help!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
4 件のコメント
Let's check the battery & charging logic. Install this gem of an app CoconutBattery. Post a snapshot of the apps main window for us to see with the charger in each port. iFixitでの質問に画像を追加する方法
さんによる
@danj Thank you for the suggestion. I just updated the initial question with the screenshots from CoconutBattery.
さんによる
Georgiy I have the same make and issue, did you found a solution?
さんによる
Same here. Any suggestion ?
さんによる
コメントを追加
2件の回答
ベストアンサー
Well, that’s interesting! One port is charging with 2.26 Watts (I assume its the 5 Volt port) and the other 4.77 Watts 19 Volts on the good.
Sadly, I haven’t seen this problem, so you’ve taught me something new!
Each port has its own power controller which then feeds the logic board its power. So I would say your logic board needs attention.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Thank you Dan! The weirdest part about this is that it appeared out of nowhere, and I'm in general extremely careful with the laptop. That said I do use it for a lot of computationally heavy tasks.
So you think there is little chance that replacing battery will resolve the issue?
さんによる
The batteries charing logic is on the other side of the USB-C port power controllers, as such it won't explain the difference between the ports.
740 cycles is still less than the expected lifespan of the battery (1,000 cycles). So I would wait awhile before going down that path.
さんによる
Great, thank you! I'll wait till they reopen Apple Stores and look into full check-up then.
さんによる
Georgiy, did you ever find anything more about this issue?
さんによる
コメントを追加
Hello, i have another kind of issue with mine ..
When i plug one or second usb-c connector (under monterey), my macbook shutdown and don’t restart it is possible that this kind of issue could be possible with oxydation of both ports.
I try to dismount my laptop soon to see if ports have oxydation or altered by humidity, in the tattoo woorkshop of my son it's too wet.
Thanks in advance for your answer.
Update (01/30/2022)
when i use quickly booth of this ports plug and unplug charger, i can read in charge or out of charge under battery notification. i suggest a trouble of oxydation and a bad contact with charger, before shutdown probably due to violent electrical short circuit.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Georgiy さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 35
今までの合計 2,554
