メインコンテンツにスキップ
ゲームボーイアドバンスのアップグレードモデル、アドバンスSPは2004年3月23日に北米で発売されました。
164回答 すべてを表示
It sorta still works? But please help
It used to still turn on but not anymore. It charges though. It fell off my table a few years ago and even though it was closed it snapped in half. It worked like that for a little bit but it doesnt anymore. This system means so much to me and Id love to fix it instead of getting a new one. But Im obviously going to need a new case at least. Please help. Check the pictures attached please
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
From what I can see on the pictures, my guess is that the ribbon cable that goes between the screen and the rest of the device has been damaged.
This because there isn’t really anything that can protect it from tear when the protective case is broken and the ribbon is what holds it together.
What you could try regarding the case is to use super glue to put the broken pieces together, just be CARFUL to ONLY PUT GLUE on the places where it has CRACKED and not to get ANYTHING ELSEWHERE.
If you are lucky and not too aggressive when using the device this will probably work, otherwise, you could look after a broken device on the internet that has a good case.
You could also look if you have anyone where you live that have a 3D-printer and ask them to model and print a new case for you.
So I think you need a new ribbon cable then first try to glue the case together and if that dosen’t work, look for a replacement.
Hope this helped!
// eke0909 :D
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Skye さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 47
