Water Left in Tub Following Wash Cycle
Upon completion of a wash cycle, there are varying amounts of water left in the tub (clear water). I had the F02 code several weeks ago and cleared out the strainer at the bottom of the machine, so I tried that again but there was nothing there. When I did this, all of the water drained out.
When I run a short wash immediately following finding water in the tub, the first thing that happens is a short flow of water followed by pumping the tub clear of water.
The water is not slowly filling the tub following a wash, which would signal the filler valve, rather there is water just sitting in the tub. It doesn’t appear to fluctuate in level if I leave it for several hours. The pump also doesn’t seem to be bad, since it will clearly pump all of the water out of the tub.
Not sure what to try next.
この質問は役に立ちましたか?
1件のコメント
Hi,
What is the model number of the washer?
jayeff さんによる
