ICraig 773 CMP773-BUN doesn´t not turn on
Hi,
My ICraig touch screen tablet doesn´t turn on and keep shutting down.
Anyone may help me, please?
Thank you in advance.
Best regards,
Handy.
I have made some progress as to the tablet not turning on or loading windows . No one on the internet seems to be getting anywhere. To get a menu to show up do this. Power completely off. Then power on and immediately hit the esc key. There you will get 6 icons.. it took me weeks to figure this out . Good luck and please thank me.
このアンサーは役に立ちましたか?
Hi, thank you very much for your answer. I am going try it and let you know later on f it works. Best regards!
過去 24時間: 1
過去 7 日: 8
過去 30 日: 14
今までの合計 744
Hi @handyhti ,
How can it shut down if it doesn't turn on?
What is actually happening if anything?
Does it do this with the charger connected and switched on?
jayeff さんによる
@jayeff Hi. I changed the USB charger in order to make sure the jack is ok. And the windows programme does not lauch properly. Moreover, it doesn´t semm to be charging.
Handy さんによる
@jayeff As you know, this tablet is equiped with a keyboard with a USB jack, in case one does not feel comfortable to use the touch screen.
Handy さんによる
@handyhti ,
OK so it was doing this before you changed the USB port?
jayeff さんによる
@jayeff I didn´t change the USB port yet. I am not using an origing ICraig battery too.
Handy さんによる
