メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2690回答 すべてを表示
My iPhone 6s is having issues with its touchscreen, helppppp.
So recently my phone has been buggy with its touch sensitivity around the start of 2020 for my iPhone 6s. I don’t know exactly why it was happening, but the problem would go away after I either turned off the phone or powered down. However, it keeps popping up randomly at moments. I think I know why. I usually drop my phone a lot in the bathroom with a hard floor. I think the many falls may have caused internal damage and messed up the touch sensors to the point where the phone would either have a hard time reacting to my touch or would react on its own when I'm not even touching the phone. The reason why I believe is this because it has gotten more apparent after I drop it more and more. One time, it accidentally flew out of my hands and hit the lower part of my wall when I was walking. After the hit, the phone started to bug with my touchscreen immediately after the impact. I powered down and turned it on again and it went back to normal. It’s not a huge issue but I want a solution to permanently get rid of this problem so that it doesn’t pop up again. I don’t wanna have to repair it, so I would like the easiest solution if possible. Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Unfortunately no easy resolution for this.
Screen is faulty and will need replacing the touch IC is failing and on the 6s model they are built into the screen.
Cheers
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
ExtraExtra さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 4
今までの合計 27
