メインコンテンツにスキップ
2015年3月にアップデートされたAppleのMacBook Pro 13" Retina Display Early 2015 はモデル番号はA1502、第5世代のIntel Core i5と i7プロセッサーが特長でForce Touchトラックパッドを備えています。
1186回答 すべてを表示
power button doesn't work correctrly
Hello,
I have the MacBook pro early 2015 and the battery was dead after 4 years so I decided to order a new one and change it. So I removed the old dead battery. After checking that nothing was destroyed by me I ordered a new one. After some weeks without the battery, while I was using my MacBook I spilt a little bit water to my laptop. I immediately disconnect the MagSafe and my pc was off. After that, I blow with compressed air the keyboard to dry the keys. Subsequently, I took the motherboard and clean it with alcohol (I haven’t isopropyl alcohol). Today I noticed that the power button doesn’t work unless I disconnect the MagSafe, pressed it for 1-2 seconds, plug in the MagSafe and then press the power key.
Any ideas??
Thanks in advance
Update (03/26/2020)
You can see how the power button behave
->https://youtu.be/uRdUsnvFl5o
->https://www.youtube.com/watch?v=VF0RxEDi...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
May be try to closely look with a ‘lens’ or microscope for any short/damage to the DC in board. Or replace it.
Careful: may be you can cause more damage by opening and analysing. At least it works now!!!
MacBook Pro 13インチ Retina Display Early 2015 MagSafe DC-Inボードの交換
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I found that the button doesn't work at all. If you disconnect the MagSafe and reconnect it without the battery it will turn on. This is the reason that it boots.
I probed the pin five of the connector of the keyboard and pressed the power button, it hasn't resistance between the ground. Is there a probability that the only key destroyed by the water is the power button??
さんによる
google for louis rossman repair in youtube. May be you can see those videos and get an idea for solving the problem!!!
さんによる
コメントを追加
回答を追加する
Κωστας Λαζαριδης さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 29
今までの合計 109
