メインコンテンツにスキップ
モデル番号A1707。 2017年6月に発売されたこのMacBook Proは、最大3.8 GHzのTurbo Boost搭載の最大2.8 GHzクアッドコアIntel Core i7プロセッサーまでのKaby Lakeプロセッサーを搭載しています。
Replacement top case - Touch ID
If a top case is liquid damaged, etc., is it possible to merely transplant the logic board and Touch ID // Power button..? Or is the power button ‘fixed’ to that unit..?
In fact, could you change the color of an A1707 and preserve Touch ID function in this method, hypothetically .. ? (That’s not my goal, but it gets sufficiently to the heart of my question) …
Thanks!!
Update (03/24/2020)
The only thing I really need to know now — is, can I transfer the Touch ID (fingerprint) // Power button to keep it with the Logic Board to which it belongs.
( I know you’ve probably answered that … but I need it to be explicit).
I have two customers who each want to keep their respective logic boards but each of whom want different colors.
They have different specs and want to keep the data on their integrated SSD … they just want the MLB and Touch ID swapped. Is that possible..?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
The TouchID button is one of the parts you'll need to move over. Once you get the uppercase you'll see very clearly what needs to move over. It took me less than a half hour to move the parts over and have a working system.
You're making this much harder in your head than it is!
The only risk is if you break something in the process.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Yes you can replace the full uppercase! Thats how Apple does it. You will need to stick with your models series. Here’s the needed part:
You’ll then need to transfer the parts over and I would add a fresh battery MacBook Pro 15" Retina (Late 2016-2017) Battery the risk of damaging the battery is quite high and it could fail on you if you transfer it.
Follow this guide MacBook Pro 15" Touch Bar 2017 バッテリーの交換
Replace a 6670 mAh battery compatible with MacBook Pro 15" Retina Late 2016 to 2017 A1707 model laptops. 76 Watt Hours (Wh). 11.4 Volts (V).の画像
製品
$129.99
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
If you have a UK or other keyboard layout you'll need a different case.
さんによる
コメントを追加
回答を追加する
trumanhw さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 1,549
