The screen is detaching from body. How to glue it back in?
The whole screen assembly is detaching from the rest of the aluminum body, starting from the top. Is there a guide on how to reattach it? What adhesive should be used?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
You can use any guide for the device to take off the screen then use any adhesive wether double-sided tape to permanent, it depends if you want repeatability or it to stay on. Also if there is any water or dust resistance, don’t rely on it after replacing the adhesive.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 118
