メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Golf Mk5は2003年秋にヨーロッパで発表され、2004年初頭に英国市場へ投入されました。北米市場では、2006年の導入時にVolkswagenが再びRabbitの名称を使用しました。
Car doesn't start after fueling
Hi Guys,
My friend has a very weird issue with his car 2004 MK5 VW Golf 1.6 FSI.
Whenever he goes to the get fuel in the car after fueling he gets back in his car and is unable to start it. This issue happens every time he fuels his car without fail.
I done some research online and saw that it may be the EVAP Purge Valve but all the posts that mention this are for GTI models and also when I tried looking for the part I could only find it for the GTI model so I think maybe that it may not be for the FSI model.
Any ideas on what could be causing this issue?
Regards
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Sounds like the classical symptoms of a closed loop EFI system that is not holding proper rest pressure on the injector rack. Without adequate pressure on that part of the fuel system the liquid fuel will vaporize and purge the liquid fuel lines with fuel vapors. There is a pressure regulator on the downstream side of the injector rack that is typically the point of failure in a situation like this. You need proper pressure testing equipment to test for this condition both before and after you replace any out of specification/failing part.
Another possibly quicker diagnosis is to turn the ignition from off to on about 10 to 20 times before attempting to turn over the engine with the starter… this action will get the fluid back up to the proximity of the injectors before you attempt to actually start the engine. If this latter suggestion doesn’t work it could be something more involved with the EFI or even electronic ignition system perhaps.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Change ur vehicle battery and then go back to buy the fuel... After putting fuel.. start ur car and go
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Joe Bitson さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 9
今までの合計 809
