メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ジーンズは履き心地がよく、丈夫かつ快適なデニム製で、日常のワードローブです。
How to repair holes in the crotch of my Tenpenny Pants
My Patagonia Tenpenny Pants have developed some holes/rips in the crotch. Most of my trousers do this eventually. Is there a repair I can make to get more life out of them? They're made of cotton/polyester
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Chub rub! Also my primary failure point for all Pataguchi pants. There MUST be an easier repair than just loosing weight.
さんによる
コメントを追加
1 件の回答
ベストアンサー
You can do an iron on patch:
アイロン接着シートを使ってパッチを当てる方法
The zig-zag patch requires a sewing machine:
ジグザグ縫いで継ぎあてする方法
Patagonia Jeansの画像
ガイド
ジグザグ縫いで継ぎあてする方法
難易度:
簡単
10 - 15 minutes
Jeansの画像
ガイド
難易度:
簡単
5 - 10 minutes
このアンサーは役に立ちましたか?
スコア 3
5 件のコメント:
I saw those,but I wasn't sure if they would work on a non-flat bit of the clothing (the crotch is a kind of saddle shop on most clothes)
さんによる
I've done it on elbows. I put a patch on both sides and sometimes hand stitch the corners down so they don't curl up. eBay has patches but most come in from China (I've had a set of denim patches ordered now for a couple of weeks but the shipping now says VOID). You can probably find them in the states just at a higher price.
さんによる
Clothing starts out as a flat piece of fabric and has curved seams to fit your shape. You can smooth down the area to where it’s flat and add a patch. You’ll follow the curved seam to keep the shape. If you are hand sewing use a back stitch which is strong and won’t loosen. For a source of patches try your local fabric stores. You don’t have to use a precut patch, you can cut your own from new fabric or my favorite, old pants ( which are already softened from wear). Denim will fray on a cut edge so just put the patch on the inside if that’s not what you like. or enjoy an edgy look.
I love that ifixit supports repair solutions!
さんによる
I’d like to know how to make the crotch longer as it is short counting from the waist and feels uncomfortable to wear
さんによる
Sorry, I believe the correct word is hanger not crotch. The pieces that goes from the waist to the crotch.
さんによる
コメントを追加
回答を追加する
Matt Freake さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 73
今までの合計 3,322
