メインコンテンツにスキップ
The Sony Handycam FDR-AX33 is a palm sized camcorder that combines 4K video with video stabilization. It was released in March 2015, and was the first camcorder to introduce the new Balanced Optical SteadyShot (BOSS).
How to fix E:61:10 flashing error in my Sony FDR-AX33
E:61:10 flashing error in my Sony FDR-AX33 I dropped it once.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
If I need to replace the steady shot assembly, where can I get this fix near me in Mansfield, Ohio. and can i fix it, or replace it myself.
さんによる
コメントを追加
2件の回答
最も参考になった回答
Georgio7564044 Error code E: 61: 10 possible cause for that is an Issue of the zoom driving part. This usually requires a new lens since parts for the internal workings are most often not available. You can always try what is shown here.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
I found the solution from trial and error while I was attempting to fix my camera. There’s a tiny circuit board with a chip attached to a ribbon and red and black cables on the right side (from your perspective facing the viewfinder/eyepiece) of the camera when the shell is disassembled. I’m assuming that’s an accelerometer or other sub-processor for BOSS. Remove it and reseat it to reset the chip.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
The one just above the headphone output and mic input?
さんによる
コメントを追加
回答を追加する
georgio7564044 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 177
今までの合計 8,113
