メインコンテンツにスキップ
digitizer ribbon cable ZIF sockets
Hi guys, I´ve followed your steps to change the ipad front panel but I messed up the “digitizer ribbon cable ZIF sockets” trying to “prying up on the hinged retaining flaps” Can I buy just that part? the front panel its perfect but i miss-understood the steps and broke those connectors…. Did I need a new complete logic board? thanks a lot!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Replacing those connectors requires some micro-soldering so unless you have experience doing this kind of work, it is not really a DIY repair.
A repair shop that specializes in micro-soldering repair should be able to do this for you. Depending on where you are located, you’ll need to consider if it is a worthwhile investment for such an older device. Alternatively, you may be able to find a used logic board for less than the cost of the repair.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Thanks a lot!
さんによる
コメントを追加
回答を追加する
joao さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 55
