メインコンテンツにスキップ
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
154回答 すべてを表示
I have water leaking from the thermostat housing
I recently replaced the water pump, radiator, and the thermostat and housing now I can not get the thermostat housing to stop leaking. Just filling the car with water it pours out as fast as I pour it into the radiator, was not leaking before and I ha e tried 2 housing along with 2 gaskets………help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
Hi,
Don’t know the answer but here’s an image of the thermostat removal and replacement procedure from the 2004-2005 Nissan Altima factory service repair manual (scroll down to Engine Cooling System) which may be of some help.
(click on image to enlarge for better viewing)
You mentioned gaskets but are the o-rings there and OK as well? Just a thought.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
could be seals or maybe the thermostat is faulty, when and where is it leaking? is it leaking out the housing or where the housing attaches to pipes? is it leaking all the time, with the engine off and cold is it still leaking?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It is a factory haousing
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
magicman9911 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 6
今までの合計 646
