メインコンテンツにスキップ
An 18.4" table top tablet with a built-in kickstand and handle, designed for high-quality video and media streaming.
35回答 すべてを表示
Can my charging port be fixed?
My galaxy view was dropped a long time ago and eventually weakened and broke at the charging port. Now the battery is dead ,it wont power on and all my pictures,videos etc, are stuck inside. Is there any way to fix it or at least get my stuff out of it. Any help would be greatly appreciated,Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi @keith13 ,
Do you mean that the charging port is broken or that the motherboard is broken in the area of the charge port?
Here’s a link to the ifixit Samsung Galaxy View Motherboard Replacement guide.
This should help you to open the tablet to gain access to the motherboard so that the damage can be ascertained.
If the problem is the charge port here’s an image of the charge port as seen in Step.13 of the guide. I’ve also added a close up view.
(click on image to enlarge for better viewing)
It is a plug in module -supplier example only so it should be easy to swap out. There may be other suppliers that suit you better, just search for Galaxy View parts or Galaxy View DC charge port to get results.
If it is the charge port or you can repair the problem if it is on the motherboard, the tablet still may not start even with the charger connected due to the failed battery. If this is the case let it “charge” for 1-2 hours before attempting to turn it on, just to see if the battery can be kick started back to life at least enough for the charger to be able to start and run the tablet for you to retrieve your data.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
yes,it is the little charging port. I just found one on line and ordered it. I will let you know how it goes in a few days Thanks
さんによる
コメントを追加
回答を追加する
james Shaw さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 22
今までの合計 494
