メインコンテンツにスキップ
2.2 GHz (Turbo Boost使用時最大3.4 GHz), 2.5 GHz (Turbo Boost使用時最大3.7 GHz)もしくは2.8 GHz (Turbo Boost使用時最大4.0 GHz) L3キャッシュで6 MBのクアッドコアIntel Core i7プロセッサ
773回答 すべてを表示
The battery I ordered can barley hold a charge.
I purchased the battery replacement kit and installed the replacement battery and it will not hold a charge. The first time I charged It completely and let it sit for 3 hours. I started using it and it seemed fine. I turned it on for the first time after installing the battery and it said 98% or 99%. I was on it for about 10 minutes and then left. I came back hours later and the battery was dead.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Many generic batteries are of very low quality. This includes internal circuitry(inside the battery that regulates and communicates with the device),and the quality of the battery itself. This is insanely common for crappy eBay batteries from Hong kong(this happens ALL the time).
It definitely sounds like a bad battery assuming that this never happened with the old battery. I’d get a new one and make sure it is a reputable brand.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I got the battery from the IFIX Kit. Do they give refund or send another replacement?
さんによる
If it’s defective,which it is,yes.
さんによる
コメントを追加
回答を追加する
Leonard Acolatse さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 38
