メインコンテンツにスキップ
2012年10月23日に発売されました。Core i5もしくはCore i7プロセッサ、Apple Fusion Driveを搭載しています。
20回答 すべてを表示
How to connect ThunderBolt Display to MacMini through Firewire
Hello,
I have a MacMini 2012 which it’s thunderbolt chip is not functioning. I really do not want to spend money on repairing it. I also have a Thunderbolt display which I was working with it before the MacMini chip broke.
Now would you please let me know if there is a way to connect my Thunderbolt display to my MacMini with a adapter from TB2 to Firewire or HTMI ?
Thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
You facing the same issue as having two people who can’t speak the others language. There is just no way for the two to have a conversation! You can’t use the FirWire connection to connect a miniDisplayPort or Thunderbolt display. There is just no means to make that work.
Your system does come with a HDMI port which you can connect a HDMI connected display. The other alternative is connect a second Mac via Ethernet between the two systems and then use Remote Desktop to then run your apps via the other Mac. Basically, running it headless. Thats what I do to manage my Mac Mini as a media server. Here I run iTunes to download and mange my music, video and podcast media.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Dear Dan,
Thank you for the straight forward answer. Then I would need to weather buy a new Mac Mini or forget using my Thunderbolt display.
All the best,
Al
さんによる
Sounds like you had your heart set on the Thunderbolt display. Yes its a great display!
Where do you live? Country and nearest city? Maybe someone can fix your logic board or see if a replacement logic board would be possible. Either option should be cheaper than getting a new Mac mini, unless yours is just underpowered for what your needs are.
さんによる
コメントを追加
回答を追加する
A.Ch さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 322
