メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPod nano 第6世代の修理情報。2010年9月発売。モデル番号:A1366。
New Battery won't Power Device
I bought a new screen and battery to repair an iPod Nano 6th Gen. I soldered in the battery and it said no charge, so I put it on the charger and the device turned on and I left it, but when I came back and removed from the charger it dies and says it needs to charge even though it shows a full battery and it is charging when I first plug it in. I put the old battery in and no issues other than it only holds about 20 minutes worth of charge. Any ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Ended up clipping the cables a little shorter on the new battery after noticing a crimp in the cable and resoldered it in. Working now.
さんによる
コメントを追加
2件の回答
最も参考になった回答
Well it can be simply that its a bad battery you bought.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
My guess, a bad battery. You said it was not charged when you got it. This is an older device so who knows how long the battery you got has been sitting around for. Lithium-ion batteries don’t hold up well when they are discharged and it can actually cause damage to the battery. I would try another battery from a reputable source and see if that makes a difference.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Arianne Morton さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 14
今までの合計 416
