MBP does not sleep with lid closed
After water damage, the MBP stays on with the lid closed. I can put it to sleep through the menu, but it will still turn on, once I close the lid. How to solve ? Thanks a lot for your thoughts!
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The location of the Hall Sensor! Click on the image is zoom it up.
You’ll need to take the logic board out and carefully clean the corrosion from the logic board using 85% isopropyl alcohol and a soft toothbrush being careful not to snag the small components as you can pull them off!
follow this guide: MacBook Pro 13インチ Retina Display Early 2015 ロジックボードの交換
このアンサーは役に立ちましたか?
Thanks! Could you clarify if the Hall sensor is on the actual logic board or as michael wrote on the magsafe 2 daughterboard.
The first image above is from the logic board and the marked part is the Hall sensor.
I’m not sure what model you have, but there are magnets located in the display panel that interact with sensors located under the top case. If there was water damage, it’s possible that it shorted out the sensor and it’s not reacting to the magnet.
If you run a paper clip along the side of the screen, you’ll find the magnet. Then closing the lid will show you where the sensor is. If it’s near where the water damage occurred, then the sensor probably needs replaced.
このアンサーは役に立ちましたか?
Hi! Thanks for the input. It´s an early 2015 13’’ MBP. What am I looking for, if I want to replace these sensors ? Are they specific ? Do they have a particular name ? thanks
@djesys - @sparklepimp is right on target here you likely have corrosion damage on the Hall sensor (see the image below)
The Hall sensor on the 13" is on the logic board on the back side.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 499
