Hi @gabby6272
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the laptop’s operating design and could damage the components.
First do not turn on your laptop and then you need to remove the battery as soon as possible from the laptop to minimize any further damage.
Then you need to dis-assemble the rest of the laptop and clean all the affected parts using Isopropyl Alcohol 99%+ (available from electronics parts stores) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and is not as effective. If you do have to use it, check the label to verify the amount of IPA. The higher the % the better
Here is a link that describes the process.
Electronics Water Damage
You may have to replace the keyboard as usually you can create more problems in the keyboard than what you had in attempting to repair it.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the laptop might possibly work correctly again.
Here is a link to a video that shows how to dis-assemble the laptop which may be of some help.
If this process seems too daunting, take your laptop to a reputable, professional laptop repair service experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
2 件のコメント
My laptop was sitting in a pool of water and now whenever I turn it on it just comes up with a bunch of writing and asking me to press any key it won’t show any other screen than that, and all the bottom lights are on, how do I get it to work please?
Loli Pop さんによる
@ Loli Pop
See the Chosen Solution below for what to do.
jayeff さんによる
