メインコンテンツにスキップ
The Kenmore Elite HE3 is a washing machine by Kenmore.
670回答 すべてを表示
Leaking from under machine since I cleaned trap
When I cleaned front trap hose was not connected to plug Cleaned trap and started machine Water drained out from bottom of machine. Rechecked trap to make sure it was tight assume hose has been missing prior to today. Started machine again Water drain to floor
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Make sure both trap inlet (pump outlet) and trap outlet hoses are secured on the trap with hose clamps and also that the trap outlet hose did not pull away from the tub. I’ve done a coin trap cleanout on this type of machine and was surprised how skewed the hose clamp / hose looked on the tub side.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Roser さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 8
今までの合計 239
