メインコンテンツにスキップ
2017年6月8日に発売。A1418 / EMC 3069 / 2017 / 3.0 GHz quad-core i5, 3.4 GHz quad-core i5 or 3.6 GHz quad-core i7 Processor.
176回答 すべてを表示
Will not power up after usb cord in rear port landed on a 110 outlet
Call it bad luck i guess. When dusting my office desk i slid the imac and the lightning cable that is plugged into the rear ports landed on a 110 outlet where another device was plugged in. The device was not plugged in all the way and the end of the lighting cable landed righ on those pins. There was a spark at the 110 plug and the breaker kicked. The usb cord only had a bad spot where it made contact. Outside of that it was fine. I have tried powering back up my imac but there is nothing. My question is do you think it killed the logic board? Power supply? I assumed logic board since the usb ports are connected to it. The logic boards for my model are almost as much as a new machine. Any advice?
Update (01/31/2020)
I took the screen off and am only getting one green LED. Just as suspected PS is fine. Logic boards for my model when i can find them are almost as muc has a new computer. I am leaning towards a used IMac, one just like mine. They are in the 650 range. Any ideas?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
6 件のコメント
Long shot, but have you checked the fuse in the iMac mains plug?
さんによる
No i didnt know it had one. Looking right now.
さんによる
The fuse you are referring to is internal correct?
さんによる
In the mains plug that goes into the socket.
If you've got another power cable try that, any kettle lead should work too.
さんによる
I can not see any type fuse on the apple power cord. The male end is like any other 110 plug and the female end is a sealed unit and i dont see how there would be room in there for a fuse.
さんによる
1以上のコメントを表示
コメントを追加
1 件の回答
ベストアンサー
You’ll need to open it and observe the Diagnostic LEDs on the logic board.
This guide will get you there.:
iMac Intel 21.5インチ Retina 4K Display (2017) ロジックボードの交換
Meanwhile try plugging it into another wall outlet than the one you are currently using.
Also try resetting the PRAM by holding down the p, r, option and command keys on start up and see if you can get it to give you a POST tone.
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
さんによる
All the #1 LED tells you is that the power supply is receiving power, not that it is working. The PSU is the the #1 suspect.
さんによる
Oh ok. So how can i test the psu? The fan does turn but acts strange.
さんによる
You replace it and see if it solves the issue.
さんによる
Ok will do.
Thank you for your time i really appreciate it.
さんによる
コメントを追加
回答を追加する
Marc Rose さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 102
