Is Samsung Galaxy S10+ waterproof?
I am looking for the Samsung phone which should be waterproof. i want to confirm this is Galaxy S10 Plus is a waterproof phone?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
IP68 dust/water resistant (up to 1.5m for 30 mins)
You can read here what means IP68
https://en.wikipedia.org/wiki/IP_Code
Dust-tight
Immersion, 1 meter (3 ft 3 in) or more depth
according to:
このアンサーは役に立ちましたか?
Hi,
No phones are truly water proof.
Water proofing gets weaker over time, so if your phone is 2nd hand or refurb, then the water proof ratings should be taken with a grain of salt.
That being said, it will give you a good idea if your phone will survive a accidental water exposer. If water does get in a phone that had high water resistance rating, odds are that the damage would be limited if any.
I don’t reccomend ever putting a phone in water on purpose. Water may find a way in. We often see water damage device with hight ip rating at the shop because the customer thought it was water proof.
I hope this helps
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 5
過去 30 日: 28
今までの合計 1,466
