Why my LG TV Screen flickering and displays horizontal and vertical
I bought LG UHD 49inch 3 years ago and now the screen diplays horizontal /vertical lines .As per LG Technician i need to replace the panel . Kindly advice do i have to replace the panel , if so where i can order the item through online. LG tech team removed the cables after opening the back cover of the TV and reconnect but still the issue remains same.
LG49UF671T
3 件のコメント
Based on the image on the screen repeating itself several times vertically, I would pop open the back of the TV and look for swollen capacitors on the main board and power supply. Noise on the power supply rails can easily cause all sorts of issues. Does the symptom change as the TV warms up? Did it get hit or dropped?
Craig Sherman さんによる
TV was not hit on anything and it was running smoothly. Suddenly a line appeared and eventually spread across the screen after 2months. LG technicians and a local technician suggested to replace the panel. I was using for last 4 years and this was the first issue noticed now.
Once I turn on the TV screen start flickering with many lines.
Shan さんによる
what happened? our tv also just started flickering all of a sudden, as per my nephew it was working fine it just happened. how did you resolved this issue?
Erwin Lamban さんによる
